Wire up to factory fogs???
Old 10-04-2007, 08:36 PM
07JKX's Avatar
Default Wire up to factory fogs???
To keep it short... i bought a new bumper that does not accomodate my factory fogs. I attempted to wire in some Pilot's and one of the lights will not turn on. It seems to flicker a couple times and then gives up. Is there a wattage problem?? The lights are 12V 55 Watt... and I have hooked them into the factory fog cables for use with the steering column switch.
Any help that anyone can offer would be greatly appreciated!
Old 10-04-2007, 09:45 PM
venom's Avatar
Trying to wire anything to those leads makes the computer angry
I ended up using the positive wire from the factory harness to kick a relay so I could wire the new lights straight to the battery
The factory leads can kick a relay without upsetting the computer but thats about all they seem to be good for.
Old 10-05-2007, 04:50 AM
07JKX's Avatar
so is there any good way to run these lights so that my fogs function on my steering column switch??
i am decent at electrical jobs... but I may be a little fuzzy on some of the terminology.
bascially, i dont want a perfectly good (and installed) switch to go to waste.
Old 10-05-2007, 04:58 AM
dsy
dsy's Avatar
use the wiring to the fogs to trigger a relay and you can run what ever you like off it.
Old 10-05-2007, 05:33 AM
WireTap's Avatar
Just to clarify, are you using the factory wiring with the after-market lights? I am not really familiar with the lights you are using but all of the lights I have used came with their own wiring harness and relays that you could trigger with the steering column lead as dsy suggested. From your description it sounds like a connection problem; possibly a ground. This could be caused by voltage irregularities if it is the factory wiring since your new lights draw more current.
Old 10-05-2007, 05:57 AM
JackMac4's Avatar
55watts is too much current. Thats why you're having issues. the factory fogs are around 35w, and are wired as such. Do a search, this has been discussed a few times.
Old 10-05-2007, 06:50 AM
07JKX's Avatar
fair enough... i will just tuck the factory wires somewhere and run the rocker switch that came with the kit.
Old 10-05-2007, 07:04 AM
scootrrydr's Avatar
Im pretty sure everyone is trying to tell you, you can use the factory fog switch to turn a relay on that lets you run your positive to the battery. Hell, I don't know if I explained it right.
Old 10-05-2007, 09:16 AM
wayland1985's Avatar
Yes... they are just trying to tell you to do this:
1: Buy a relay (or use the one that came with your fogs, if it came with one)
2: Wire the factory fog light lead to the relay
3: Install fog lights with a new fused power line from the battery
4: Use your aftermarket fog lights like your stock fog lights
Old 10-05-2007, 04:59 PM
07JKX's Avatar
i appreciate all the input... but apparently I am not as familiar with this type of project as I most likely should be.
After doing a bit a research... i have determined a "relay" takes a smaller amount of current and swirls it around via "electromagnet" to generate a larger amount of current... am I correct??
If so, where could I pick one up and for how much that would be suitable for this project? The lights came with a fused power line (15... i assume amps)
basically... i would like to attempt this b/c it would further my knowlegde of electrical systems... but I dont want to overload, set on fire, short circuit, or otherwise damage my vehicle. Maybe i should practice on a friends car when he is out of town???
Okay... i am going to go track wires... is there anything to look for as the"factory fog light lead" is concerned. Will I need to wire it in any particular location or just make sure I run the lead into the relay?
Quick Reply: Wire up to factory fogs???
