Wiring contura v rocker switches
Does anyone have these rocker switches and if so how did you wire them up? Trying to wire up our LOD bumper today. Sorry complete noob when it comes to wiring in general.
1 Attachment(s)
That helps a little bit lol
I still don't understand what 2,3,7, and 6 are for.
1 Attachment(s)
This is why I have
#2 - Connects to your the battery
#3 - Connects to your relay #86 #6 & 7 - Both are ground #8 - Connects to your dash/light Illumination wire |
2 Attachment(s)
This is what I'm trying to do. I got the light switch to work where either the led light inside the switch will come on or the rear light on the bumper will. Any ideas!
And where is the dash illumination wire?
Originally Posted by jkambulance
(Post 3072808)
. Any ideas!
1) Do you want the LED on the switch to come on when you flip the switch? Do this: Accessory power to pin #3 on the switch. Relay trigger wire to pin #2 on switch. On Switch - Jumper wire from pin #2 to pin #8. Ground wire to pin #7. 2) Do you want the LED on the switch to work like the dash lights? Do this: Accessory power to pin #3 on the switch. Relay trigger wire to pin #2 on the switch. Dash illumination wire to pin #8 on the switch. Ground wire to pin #7. |
Originally Posted by gadget799
(Post 3072218)
