Wiring contura v rocker switches
Does anyone have these rocker switches and if so how did you wire them up? Trying to wire up our LOD bumper today. Sorry complete noob when it comes to wiring in general.
This is what I'm trying to do. I got the light switch to work where either the led light inside the switch will come on or the rear light on the bumper will. Any ideas!
Ya, I got a couple.
1) Do you want the LED on the switch to come on when you flip the switch? Do this:
Accessory power to pin #3 on the switch.
Relay trigger wire to pin #2 on switch.
On Switch - Jumper wire from pin #2 to pin #8.
Ground wire to pin #7.
2) Do you want the LED on the switch to work like the dash lights? Do this:
Relay trigger wire to pin #2 on the switch.
Dash illumination wire to pin #8 on the switch.
