Wiring harness
Old Sep 10, 2007 | 07:12 PM
duhonsr's Avatar
Default Wiring harness
Does any one know where I can get a factory plug to get video out for the 6 disk cd/dvd player for a 2007 4 dr Rubicon. The kid get crazy on long trips.
Old Sep 11, 2007 | 07:29 AM
JackMac4's Avatar
There is none...you have to make it yourself. See beermonkey's thread in the FAQ.
Old Sep 11, 2007 | 08:19 AM
skydyvyr's Avatar
Sorry to disappoint JackMacOKC & beermonkey, but the connector is available from your local dealer. It does require some assembly, but if you are handy at all it shouldn't be a problem. The DCX part number for this connector is: 5083221AA (20 Pin Connector) I've seen prices ranging from $29 - $60 depending on the dealer.
When you receive the connector, you'll get the a bag containing the connector and 20 ~6" wires with pins crimped on the end. All you have to do is insert the pins you want to use and press the locking bar on the bottom of the connector to lock them in place. You can find detailed write-ups on how to do this with pictures on the Internet. Unfortunately I didn't take pics when I did it as the information was already readily available.
I may contact the poster of one of the write ups I used and ask if he would mind if I post his pics here.
Old Sep 11, 2007 | 03:04 PM
duhonsr's Avatar
Default Thanks
skydyvyr Thanks for the post The Pic will be fine if you can but if not dont worrie about it I figure something out. Thanks for the Part number.
Old Sep 11, 2007 | 03:55 PM
zoomzoomjr's Avatar
skydyvyr, is that the part I have been searching for? None of the dealers around have been able to help me (but I have only been on the phone).
Old Sep 11, 2007 | 09:59 PM
skydyvyr's Avatar
I'm not sure... what part have you been searching for?
If it happens to be the 20 Pin connector that connects to the back of any of the stock radios (including MyGig) then yes, it is the part. On the back of the stock radios, there are two 20 - Pin connectors and one 10 - Pin connector. Both of the 20 - Pin connectors are the same; although the wiring that connects to them is different.
Old Sep 12, 2007 | 03:57 AM
zoomzoomjr's Avatar
In my other thread I was looking for a plug that fits into the back of the 6 disc, for video out. I was asking all of the dealers for the plug for the nitro video kit.
Old Sep 12, 2007 | 08:59 AM
skydyvyr's Avatar
Thumbs up Nitro Video Kit...
According to the wiring harness diagrams in the Nitro Service Manual, there is no single loom for the Nitro rear seat video harness. Complicating matters is that the Harness that does connect to the rear display is part of the Headliner installed in the Nitro, so most likely, if there is a Kit that can be installed or ordered by the dealer it doesn't include any wiring between the Head Unit and the rear monitor.
The Standard Dash Loom for the Nitro includes all three plugs that connect into the back of the HU, so a parts guy at the dealer (without specific knowledge of the electrical connectors and where to find them in the parts lists) will not be able to find the connectors we're looking for. These connectors are not listed or displayed in the exploded diagrams that they use to find parts.
Regardless of that, yes, 5083221AA (20 Pin Connector) is the connector you want for the 6 Disk changer. Using this connector in conjunction with beermonkey's write up will work.
Old Sep 12, 2007 | 11:57 AM
zoomzoomjr's Avatar
thanks for all the info!!! really appreciated, now i can yell at the dealers again...
Old Sep 12, 2007 | 12:29 PM
skydyvyr's Avatar
I shared some incorrect information here... The best price I've seen for this connector is slightly less than $40, not $29. I had it confused with another one I've purchased.
Sorry...
