Wiring Question
Old Feb 6, 2012 | 07:27 AM
2saharas's Avatar
Default Wiring Question
I recently installed two sets of KC lights on my jeep. I just hooked the low power wire to the battery for supplying the switch with the power to turn on the relay. I was wondering if anyone knew of an easy place to hook this wire up that would be hooked to the ignition so i dont have to worry about my daughter turning the lights on while the jeep is parked and ending up with a dead battery later.... Some place under the hood would be ideal since the wiring is already in that area.
Old Feb 6, 2012 | 08:21 AM
WhosUrBuddiee's Avatar
If you have already run the switch into the cab, just use a vampire clip on the ignition hot signal to the cigarette lighter into the + terminal of the switch, the - of the switch should still go to pin 85 of the relay.
Old Feb 6, 2012 | 08:29 AM
JK-Ford's Avatar
M8 or M9 slot on the fuse box. Thank Ron for this write-up.
https://www.jk-forum.com/forums/show...highlight=tipm
