Wiring question
So I recently installed a Kenwood DNX570HD into my JKU. I've already added speakers to my jeep before hand and it wasn't enough, now I'm planing on amplifying my speakers and adding a sub into it as well. My question is when running the wiring from the amp to the sound bar how to I run those wires into the speaker is there an access for me to run wires into it do I have to tap a hole somewhere? TIA guys
You can run wiring up the passenger side behind the plastic where the seat belts are installed (on a '12 2dr). The factory wiring runs up from the ground there and continues towards the front along the plastic door trim. Once up the you can run wires inside the sound bar, I would recommend a padded loom of some sort. I used copper pipe insulation (taped it down too) and ran that through the sound bar to keep the wires from slapping around in there.
