Is it worth getting chip flasher?
Old Oct 20, 2012 | 03:28 PM
Matthewd5's Avatar
Default Is it worth getting chip flasher?
I'm really interested in deciding if its worth buying a chip flasher...
I have a 2012 Sport S with the six speed
The only reason I can think of for the chip flasher right now is I just upgraded from 255/75/17's to 285/70/17's so I imagine the speedo is off a tiny bit, but seeing I don't have an automatic there are no electronic shift points to tweak.
Matthew
Old Oct 20, 2012 | 04:01 PM
OJK12's Avatar
If you mean a programmer the only thing currently available for the 2011+ is the procal from AEV. It will fix your speedo and allow adjustments to tire pressures but there is no tune in it. Most members are waiting for a tuner and there is even a petition thread to get one but they have yet to crack the codes.
Old Oct 20, 2012 | 05:32 PM
Matthewd5's Avatar
Ok thanks
That is what I was referring to
So I can change the wheel size and the low air warning setpoint
Can the dealer reset the tire size? It seems that I read that somewhere
Matthew
Old Oct 20, 2012 | 07:16 PM
OJK12's Avatar
I'm not sure if the dealer can or not but if they can I'm sure there is a thread about it. The procal does a few other things too but off hand I don't know what they are.
Old Oct 21, 2012 | 03:38 AM
Matthewd5's Avatar
everything i've found about it is about automatic transmission shift points and tire size or daytime runningl lights
tire size is all that really interests me and even that isn't that big a deal considering i just moved up from 255/75/17 to 285/70/17
matthew
