2012 JKUR build -tons and stuff
Old May 26, 2018 | 02:36 PM
Dzldust's Avatar
Just added a rear AntiRock and a Teraflex forged rear trac bar
Old Aug 31, 2018 | 12:18 PM
Dzldust's Avatar
Noticed when bouncing or dropping off ledges the pitman arm bolt would hit the Tie rod npbadly,so I notched the frame and flipped the Draglink,now I’m free and clear and not contact when coming down hard
Old Feb 6, 2019 | 02:35 PM
Dzldust's Avatar
Old Apr 24, 2019 | 06:09 PM
Dzldust's Avatar
Finally got around to removing old armor and torn up fenders and replaced with EVO full rear armor and modified Smittybilt Flux XRC fenders,also added RockHard C-pillar supports .This setup is a lot stronger and I’ll be bracing it laterally inside for even more strength for future impacts
Old Jul 11, 2019 | 05:59 PM
Dzldust's Avatar
Added a Kargomaster LoProrack system,comes with a nice rear bar and bolts through the hardtop,I took a Garvin rack I had laying around and shortened it and with the existing threaded holes in the rack ,just bolted it on .Came out nice and am going to mount a RhinoRack Batwing to it shortly
Old Jul 11, 2019 | 06:03 PM
Dzldust's Avatar
Well shortly after mounting the Kargomaster rack on it got a test for sure,a layover that took the top out but Jeep did not roll over partly due to the rear rack support bar attached to the cage ,it supported the crushed hardtop and kept the Jeep from rolling completely onto its side .I found another hardtop and fixed it the next day,The Kargomaster rack system held up and was still straight but the hardtop and side window didn’t survive .The smoking picture was after I reversed it back onto all 4wheels,it was balancing on the passenger rear tire for a few second and I barely backed it out ,all along the motor was clatter8ng and smoking like it was on fire,had to add about a quart of oil once back to camp
Old Jul 11, 2019 | 06:05 PM
Dzldust's Avatar
Bashed the Rockhard engine skid plate in pretty hard,after inquiring about a replacement and gett8ng the runaround I just figured I’d straighten it and weld it in this time
Old Jul 11, 2019 | 06:07 PM
Dzldust's Avatar
This is RiverRock Orv in Milledgeville Georgia by the way
Old Jul 11, 2019 | 06:09 PM
Dzldust's Avatar
Had a bent control arm after the last Windrock ride,Rusty’s off-road went out a replacement right away.Great company if you ask me
Old Jul 11, 2019 | 06:11 PM
Dzldust's Avatar
The DV8 tire carrier did not like the small tree I backed into,it folded to the drivers side and flattened the thin tube it’s made out of ,nice rack if you want to hold a big tire for the mall but not something I’d buy again for wheeling .Good design but thin walled tubing. I might cut it apart and use better main tubing that can take a hit .
