Anvil 2015 JKU Sport Overland Build
Installed a external CB speaker for my cobra 75 in the roll bar foam. I cut a notch out of the foam and installed the speaker. Once the padding is on, you will never know its there and it will speak right into my ear. I enjoy keeping the windows down, and the cobra 75 built in speaker is not enough. I say this considering that the cobra 75 is on my grab handle. It gets muffled quickly. This should solve that issue.
jeep129 by Chris Yuknis, on Flickr
Did some more work on the drawers tonight.
Routed the edges round and got to work on the actual drawers in the box. The bottoms are dado'd into the sides and front/back. We will be using 500lb lock in and lock out slides.
jeep130 by Chris Yuknis, on Flickr
jeep131 by Chris Yuknis, on Flickr
jeep132 by Chris Yuknis, on Flickr
Here is a shot of Nicks 4Runner setup. He will have two drawers on the bottom, and two on top of the bottom platform on the right. The fridge and slide will go on the left. I am pretty jealous of all the space the 4Runner has. My box will be roughly the same size as his upper box with two drawers.
jeep133 by Chris Yuknis, on Flickr
jeep132 by Chris Yuknis, on FlickrHere is a shot of Nicks 4Runner setup. He will have two drawers on the bottom, and two on top of the bottom platform on the right. The fridge and slide will go on the left. I am pretty jealous of all the space the 4Runner has. My box will be roughly the same size as his upper box with two drawers.
An important part of the drawers was having them sized correctly for fluids etc.
jeep134 by Chris Yuknis, on Flickr
The bottom drawer will have permanent dividers installed. Then, once line-x'd it will create a watertight pocket that will isolate the spillage to that pocket alone should anything break, leak, etc.
jeep135 by Chris Yuknis, on Flickr
The upper drawer will be made to accept dividers later on if desired. The dividers will be made from black walnut to match the drawer fronts.
Here the box sits prior to final assembly, line-x, and cosmetics like the the drawers face.
jeep136 by Chris Yuknis, on Flickr
jeep134 by Chris Yuknis, on FlickrThe bottom drawer will have permanent dividers installed. Then, once line-x'd it will create a watertight pocket that will isolate the spillage to that pocket alone should anything break, leak, etc.
jeep135 by Chris Yuknis, on FlickrThe upper drawer will be made to accept dividers later on if desired. The dividers will be made from black walnut to match the drawer fronts.
jeep135 by Chris Yuknis, on FlickrHere the box sits prior to final assembly, line-x, and cosmetics like the the drawers face.
Next came time to chose the wood for the drawer fronts. Nick @ Backwoods Overland has an amazing collection of woods at his shop. In the end we chose Black walnut for the drawer faces. I think it will look awesome once finished in a dark stain against the black line-x.
jeep137 by Chris Yuknis, on Flickr
jeep138 by Chris Yuknis, on Flickr
For me, it was amazing to see this lumber go from a raw slice of a lumber, to a finished board.
jeep139 by Chris Yuknis, on Flickr
jeep140 by Chris Yuknis, on Flickr
jeep138 by Chris Yuknis, on FlickrFor me, it was amazing to see this lumber go from a raw slice of a lumber, to a finished board.
I started the install by bolting the ARB slide to the plates. I had to drill my own holes as the built in nutserts were placed for the indel fridge slides.
jeep141 by Chris Yuknis, on Flickr
Here is a final mockup of the drawer system. Fresh in from the local Line-X and ready for assembly!
jeep142 by Chris Yuknis, on Flickr
Here is a teaser of the Drawer fronts which are made from Black Walnut. The fronts will be stained, french polished, and then coated with a matte finish. This should give the fronts a subdued, but very three dimensional look.
jeep143 by Chris Yuknis, on Flickr
After a long night of assembly and fitting the system is in!
jeep144 by Chris Yuknis, on Flickr
jeep145 by Chris Yuknis, on Flickr
I just need to finish the fronts and add the locks as we will be good!
jeep141 by Chris Yuknis, on FlickrHere is a final mockup of the drawer system. Fresh in from the local Line-X and ready for assembly!
jeep142 by Chris Yuknis, on FlickrHere is a teaser of the Drawer fronts which are made from Black Walnut. The fronts will be stained, french polished, and then coated with a matte finish. This should give the fronts a subdued, but very three dimensional look.
jeep143 by Chris Yuknis, on FlickrAfter a long night of assembly and fitting the system is in!
jeep145 by Chris Yuknis, on FlickrI just need to finish the fronts and add the locks as we will be good!
Installed some morimoto LED Reverse lights
jeep146 by Chris Yuknis, on Flickr
jeep147 by Chris Yuknis, on Flickr
Found some awesome bags that strap to the roll cage on Amazon.
jeep148 by Chris Yuknis, on Flickr
jeep149 by Chris Yuknis, on Flickr
jeep150 by Chris Yuknis, on FlickrInstalled mopar headliners and stuck a few patches up there while I was at it.
Windows removed!
jeep151 by Chris Yuknis, on Flickr
Sliders installed! Write up coming soon...
jeep152 by Chris Yuknis, on Flickr
jeep151 by Chris Yuknis, on FlickrSliders installed! Write up coming soon...
