Build thread on my 2012 JKU Rubicon
NTHINUF - sorry I tend to get long winded when I try and explain stuff I guess. I'll keep it simplified from here on. Thanks for the advice, I will look into the budget boost stuff.
JKFORLIFE - Thanks. I don't plan on going crazy with stuff. Just small stuff here and there. From what I've seen a 2-2.5 will get it sitting about how I want it.
THE DIRTMAN - I appreciate the advice, and I am mainly wanting the lift to improve the stance on the jeep. When I look at it it looks squished down if that makes any sense.
RESHARP001 - I was thinking 3" would be a little much for what the jeep will be doing 99% of the time. I have really been considering the quadratec 2" coil spacer lift with fox shocks. Part # 16116 0311. Does anyone have this or know anything about it?
Thanks again all that have responded. I do appreciate it.
The Quadratec boost you are asking about is nothing more than 4 shocks (~$340 value) with 4 pucks and front bumpstops ($160 value). That little package doesn’t include drop brackets for your brake lines, rear bump stops, or longer rear sway bar links which you'd probably want to add. I'd say address your caster as well.....and address re-centering your axles if that bugs you.
