I know what I read but is it really true?
I'm not much into off-roading but I have been considering a very moderate lift, maybe 1-1/2" to 2". Nothing serious you understand. My only fear is loosing even one ounce of road-ability or loosing any suspension and alignment integrity. I will not do this if there's any hint of excessive tire wear or steering characteristics. I do plan on staying with the stock size tires and wheels.
Offroad, tire wear depends on the terrain and, more important, on how you drive. If you take it easy, do not spin tires (or spin as little as possible), and air down, tire wear wouldn't be a problem.
Airing down, to 20psi or less, reduces rubber friction and spreads the grip over a larger area, which is easier for the Jeep and tires, and also softens the ride.
Road handling won't be hurt.
Tire wear depends on the terrain and, more important, on how toy drive. If you take it easy, do not spin tires (or spin as little as possible), and air down, tire wear wouldn't be a problem.
Softer ride? Yes, that is true. The rest of it spells disaster.
Don't lift it. Just place a 3/4" spacer on the front springs. Just doing this may drop mpg a notch or two due to change in aerodynamics. In the future get the same size tire but with a slightly more aggressive look, but this too may drop mpg from increased rolling resistance. Wheel spacers to increase track will improve how it feels in turns.
Added 'Offroad' to make it clearer.
If you want your jeep to act and preform like from the factory on the road. Then save yourself some money and leave it alone. If you like it the way it is don't change it. The engineers have made it a great road vehicle.
I'm incline to agree with you. I would at least like to level it out.
