4 high/low uses
#41
Ok, newb alert. I've got a '13 JKUR and I was told to use 4lo pretty much all the time on trails, especially on climbs and descents. I noticed that on a steep descent if I had it in D, then it would roll very slowly for a bit, shift and then I'd have to get on the brakes to keep from going too fast. When I kept it in D1, then I'd hardly need to use the brake at all. When should I use D vs D1 vs D2? Also, those are the only gear options right?
#42
#44
#45
#46
#47
The end goal is if you're doing a lot of downhill, you want to use a combination of brakes and gearing. Don't over-rev or put too much stress on the motor, don't ride the brakes and bake them to a mushy, burnt mess. If you can't do that, then use this magical "hill decent" button
The owner's manual, or "Manuel" as we refer to him on here, will refer you to the operation of "hill descent" if you have that option.
Yes! Lots of people "lock out" in 1st gear while climbing. Shifting creates heat, heat is bad for automatic transmissions. Keep the transmission in a gear that's turning the engine 2000-3000 rpm so that fluids are circulating well. Just don't exceed 15mph or so in 4-low, and that goes for you, too, Manuel (6-speed manual).
