12 rubicon auto. Went wheeling this past Sat and used 4 low for the first time. I noticed the transmission went into 1st gear at the same time I shifted to 4 low. Does have to be in 1st? Is it possible to go any higher? I was going very slow an revs were high. Most post I read say low up to 20 mph but I don't think I could even get close to that w/o blowing engine. Adding that I tried to shift but it stayed in 1st. I needed to get moving and could not play with it more.
Thanks |
I'm assuming you have an automatic. In short, the transmission will switch gears, but it'll be at much higher RPMs, so that you can always have torque when you're using 4lo.
By the way, select shift just holds it back from 3rd. It'll allow the jeep to go to second if need be, but wot put it directly into second. It'll still select first until it needs more gear.
Originally Posted by NCRUBI2012
(Post 3625607)
Thanks |
Originally Posted by Tooadvanced
(Post 3625964)
With select shift you can select gears in 4lo. Where I go wheeling ill have 1/2 mile of tight technical crawling then 500ft of easy dirt road so I tap to 1st for hard part then tap to 2-3 for easy section. Never had a problem and yes the jeep will start off from 2nd from a stop |
