4low
4low
Well I went to the beach and got into some loose sand so I put it in 4 low and got through the sand so I wouldn't get stuck like everybody else on the beach. When I went to leave and got back to hard ground 4 wheel drive lever just moved back and fourth easy and would not come out of 4 low....had to have it towed!! Anybody ever seen this? 2009 x unlimited..33s 3inch lift mud grapplers. Thanks
Sounds like one of the plastic bushings broke. There is one on each end of the transfer case shifter linkage. Parts will cost you a whopping $0.50 each
They get hot, brittle and eventually break.
If it ever happens to you again you can get under the Jeep and manually shift into 2WD to get off trail or home.
