JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Coil over install ?
Old May 14, 2020 | 03:37 PM
Sheld246's Avatar
Default Coil over install ?
Whos has installed coil overs with out the use of a car lift is it possible and did you use regular jack stands or have buy massive jack stands like a set of sunex jack stands from northen tool ?
Old May 15, 2020 | 05:33 AM
TheDirtman's Avatar
You will need to jack the jeep up enough to get the fully extended shock in there. You can pull the tires off so you can droop the axle and make it easier.
Old Oct 29, 2020 | 12:00 PM
maverick1090's Avatar
DId my coil overs prior to having my 2 post lift installed. It was not fun, and I wouldn't do it again.
