Engine Shut Down when Using the Winch
....Plus the fact that the brick column you were pulling could have weighed more than you think. And it's a lot different pulling something like that, than pulling a rolling load.....even a stuck JK can roll probably a bit better than a brick column (depending how large it is of course). Like what was said, you pull something that doesn't want to move at all, and that winch will ask for all kinds of more power.
Ah ha, I may have found the problem: Over the weekend I found that the battery cable on the positive battery post was loose. I made a couple of Homedepot runs and had experienced slow cranking when I hit the key. When I got home...click, click, click. No cranking. I traced the problem to the loose battery cable. Tightened it up and everything is good-to-go. Now I'm wondering if this had an effect on the winching or engine shut-down issue. Perhaps I should pull down someone's brick column to test my theory. Any volunteers?
