JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
GPS Question
Old Apr 20, 2013 | 07:14 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Default GPS Question
Iv got the factory radio with the GPS
but it doesnt seem to do very well when off road.
Is there a GPS that would work off road as well as on?
Thanks.
Old May 5, 2013 | 05:27 AM
LoneWolf's Avatar
I'm curious, too. I don't have any factory GPS and want to make sure I get one that will be of use off-road.
Old May 5, 2013 | 06:40 AM
OH9JK's Avatar
JK-Forum Ambassador
They are expensive but best around....
http://www.lowrance.com/en-US/Produc...aja-en-us.aspx
Old May 5, 2013 | 08:05 AM
caprob's Avatar
Why buy a marine unit? Just buy an I-pad Mini like my team member "Stormtrooper"did or my favorite ( I'm an Android fan) Samsung Galaxy Tab 3 (8inch) and the software. Make sure the tablet either has a true GPS, like mine, in it or blue tooth capable to recieve a position fix without wi-fi from a external source like my DeLorme In Reach sat communicator, that way when you loose cell signal, and you WILL, you won't loose your navigational ability. I use the In Reach as a PLB by the way.
RAM has many cool mounting options for this stuff too. I have a RAM ball glued to the passenger side roof panel to the right of our single sideband which is above the rearview mirror. This lessens the visual restriction usually incurred by the typical windshield suction cup mounts. (my smartphone and Escort are below the mirror already on suction cups) Check out Ebay if you cant find them from a Project JK supporter first. It helps GREATLY to put armour on the tablet so the mount can grip it better!
The best software I've found so far is Back Country Navigator Pro. ($10 @ Google's "Play Store") Then pay the annual (small) fee for topo & sat image downloading access once you have downloaded BCNP. AccuTerra Maps, I believe, I paid $19.95/yr and Digital Globe is $24.95/yr. Once you have completed this you will open up the menu for choosing which topos to download. Only download what you honestly think you'll use because these take up a great deal of memory. I bought a 64gb micro sd for the tab, filled it up before finishing the areas of Colorado that I needed with some local Louisiana BS so I could play with it. I had to go back and erase a ton. This process of loading takes time but once you're done then it's fantastic. In the process I learned a great deal about the Colorado back country we will be off-roading in all this 2014 late Spring on up until early Fall.
Another program I thought looked good was Gaia ($19.99) but it seemed BCNP had more followers. Trimbles software looks easy but it also looked like a toy to me for $4.99. All this stuff is VERY inexpensive compared to what I've dealt with in yachting and now, a step down to shipping where software can run in the thousands and map updating services are hundreds per year.
We have a Garmin Dacota 20 as well loaded with the topos for when we hike away on foot so we cant get lost. Garmin has much better hardware now. (see Monterra $650).
Good luck and please say hi if you see Becca and I in "Hazardous" on the trail.
Old May 5, 2013 | 08:31 AM
SRJeep's Avatar
The handheld units that are used for hiking are excellent for off roading. Nice thing about these is that they are very versitle rather than a permanent hard mount.
Old May 14, 2013 | 03:46 PM
RubiconGeoff's Avatar
Handheld units like the Garmin Oregon are too small and hard to read while driving. I much prefer the Google Nexus 7 with BackCountry Navigator and/or Every Trail.
