JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Hi Lift jacking
Old 09-05-2008, 01:32 PM
JeepSWAG
Sponsoring Manufacturer
Woods's Avatar
It's not a JK and near as I an tell, it's not lifting the Jeep, but does anybody know how and what is going on at the end of this video?
http://www.youtube.com/watch?v=Ie5l5YNd1R0
Old 09-05-2008, 01:49 PM
bly109's Avatar
Do you mean using the highlift to hold the axle in the Jeep?
Here's the recovery we did on my bro's XJ after he snapped his shaft. We were going to use the highlift frame, but then Usgaone remembered seeing an "axle roller" for rent in the office at Raucsh creek. It worked really well.
Old 09-05-2008, 02:22 PM
Desert Fox's Avatar
Smile
I used my Hi Lift many times when I had my TJ. One look at the JK and I added a steel front winch bumper, rock rails and a trailer hitch. Problem solved. Most frequent uses for me have been to stack rocks and to "slide off" when high centered. I've never had a flat tire. I also carry a 14" X 14" piece of 3/4 inch plywood to put under the jack when in sand.
Old 09-05-2008, 06:08 PM
CIJeep's Avatar
Originally Posted by pastorsteve
The tire mate looks cool - but for what purpose? You can't change the tire and you can't jack up and .............?
Sure you can, just put something under the axle tube and be sure to block the wheels on the other axle.
Use a rock under the axle, you know...on a solid rock I stand.
Old 09-07-2008, 07:43 AM
easttnruby's Avatar
Originally Posted by hunter0781
I was actually going to post something similar to this today....has anyone used a high lift jack on the stock rubi rails with success?
I have used the hi lift on the rubi rails. all held up fine and no problem. I like to lift from a D-ring though for a little more stability. Its kinda scary when the jeep shifts and you can see the jack sway side to side.
Old 09-07-2008, 09:02 AM
pastorsteve's Avatar
Thanks for that. I do think you mean: He lifted me out of the slimy pit, out of the mud and mire; he set my feet on a rock and gave me a firm place to stand.
Psalm 40:2 but thanks.
Old 09-07-2008, 12:51 PM
User 12721's Avatar
Helped a fellow member on here jack up the front end of his JK with a hi-lift using the stock bumper...we just put it in the center of the bumper and there wasn't any damage afterwards.
Old 09-07-2008, 12:54 PM
Great thanks. I've used my old one on CJ's easily enough but not on the JK yet. Maybe when I strip or change out the bumpers it'll be easier.... that and maybe rock rails for the side.
Old 09-08-2008, 07:31 AM
Jarne's Avatar
They call the jacks "Widow Makers" for a reason. I have ran calls where the jack fell and crushed the person underneath. The handle can also kick-back and pop ya if you are not careful.
Old 09-08-2008, 07:34 AM
Ahhhhh I remember now. Those handles can be a little jumpy.
Quick Reply: Hi Lift jacking
