JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
need help with sand
Old Sep 23, 2009 | 07:30 PM
zero_traction69's Avatar
Default need help with sand
so i have had problems driving on sand and i need help when starting out i get a really bad like shake and idk what it is? like its almost like wheel hop but i am not sure so anyone got any good tips?
Old Sep 24, 2009 | 04:06 AM
dxbjeep's Avatar
You mean when your just starting to drive on the sand or after you've been driving in sand?
Old Sep 24, 2009 | 06:14 AM
jkkat's Avatar
lower your air pressure and use low gear.
Old Sep 24, 2009 | 09:39 AM
its like i will be going fine but then if i stop then go again i get it really bad!! LOL
Old Sep 24, 2009 | 01:32 PM
TRJeff's Avatar
Default wheel hop
Sounds like you were in 4hi, If you are staying in 4 hi, push the ESP off button, sounds like your traction control is kicking in you need to turn traction control off. I have experienced the same feeling in certain snow conditions also.
Old Sep 24, 2009 | 03:13 PM
Yoda's Avatar
disable the esp in the sand !!!
Old Sep 24, 2009 | 03:49 PM
IMFletch's Avatar
As others have said; in the sand you should air down to at least 18 psi, be in 4Hi and turn off ESP. Remember in a Jk ESP will re-engage everytime you turn the motor off. I almost found out that little detail the hard way.
Old Sep 24, 2009 | 09:00 PM
esp was off first thing i do before going off road it was just weird like it felt like it was getting no power and just the whole thing was shaking i thought i broke something at first but nothing is broken. i didnt let air out of my tires thought so i will try that next time
Old Sep 25, 2009 | 04:36 AM
IMFletch's Avatar
The loss of power and shaking feeling is due to the ESP engaging in an attempt to limit wheel spin and regain tracking. That is a good thing if you are on a wet road but a bad thing if you are on sand. In soft sand in particular, some wheel spin is inevitable but also necessary to maintain momentum when wheeling in the sand.
Old Sep 25, 2009 | 05:34 AM
dxbjeep's Avatar
have you held the ESP button for 5 seconds to turn it off completely? only reason for shaking can be the following:
tires at full pressure
going over ripples in the sand,
ESP not fully disengaged and pulling back the power
