Rear Diff Leak - Need Help
Not sure exactly where this thread belongs.
While backing off an obstacle I hit the bottom of my rear diff on a rock. I thought no biggie, but two days later there was one drop of diff fluid on my garage floor. The bottom of the cover, a little of the carrier and the bottom cover bolt was scuffed.
Do you think that I can take it to the dealer and have them remove the cover, reapply the gasket and bolt and hopefully call it a day?
or
Should I just order an aftermarket diff cover?
or
Is it possible the carrier/third member is screwed and I'm facing a very costly repair?
Any personal experience would help. Are the carrier and cover made out of different metals? Is one softer than the other?
I've been wanting to replace my diff covers, but kept putting it on the back burner. I also have to admit that I was going to replace the front before the rear assuming it was more in harm's way.
THANKS IN ADVANCE
or
or
THANKS IN ADVANCE
Is the cover bent? Did you try tightening the bolts? I bet you have a loose bolt.
Look for nodular iron or plate steel. Lots of good ones out there. I have Dynatrac but they're pricey. I like Riddler/Crane. Some others I like but I don't think I can mention here. Do your homework.
You just reminded me that my buddy mentioned that the bolt might be loose. I'm going to check it in a minute.
Would the cover be obviously bent?
I was thinking Dynatrac or Teraflex.
Thanks for the help!
The cover is chewed up pretty bad, but so is the carrier.
The bolts are tight.
From the factory, is the gasket liquid or a predetermined shape? Is it possilbe that part of it could have been pulled out? Seems unlikely.
I'm thinking about just ordering the rear cover. I just hope that I dont drop the cash on it and it still leaks.
jkkat
I know I got all preachy in your flop thread. Hopefully you saw me retracting in the subsequent posts. Thanks for jumping in and offering up suggestions.
I think I'm going to pull the trigger on Riddler diff covers.
x50 on getting real covers...
and if I were you I would also dot he front cover.. if you bang the front cover against a rock it can bend into your gears.. usually, when you hit the rear it just peels away and leaks.. although in reverse, its the opposite
Well, had a local offroad shop replace both front and rear diff covers.
It cost $275!!!
One hour of labor per axle + tax & fluid. Tech had to grind on the inside of each cover to clear the locker actuator. We knew this was needed via the PDF on Solid's web site and included instructions. The front required much more grinding than the rear. I'm happy to have them on, but did not think it would cost sooo much. I should have bought all the tools to do it my self. Guess I was just being lazy.
I'm very happy for this forum. He and I had a lengthy discussion over the amt of fluid to put in there. He would have over filled had I not noted the original fill level.
It cost $275!!!
One hour of labor per axle + tax & fluid. Tech had to grind on the inside of each cover to clear the locker actuator. We knew this was needed via the PDF on Solid's web site and included instructions. The front required much more grinding than the rear. I'm happy to have them on, but did not think it would cost sooo much. I should have bought all the tools to do it my self. Guess I was just being lazy. I'm very happy for this forum. He and I had a lengthy discussion over the amt of fluid to put in there. He would have over filled had I not noted the original fill level.
