Recovery Gear
Well I go 4wheeling almost every weekend and me getting myself stuck is inevitable. I know I need some tow straps, a snatch block, some d-rings, a trunk protector, and a metal chain. Any brand recommedations or anything else that you veterans have found that comes in handy in those sticky situations?
I think you need a chain; but not just any chain. Get 3/8 Grade 70 Tansport chain. Get a 20 ft length with grab hooks. But be very careful to get good quality domestic chain - no Chinese crap. Look in the phone book under "wire rope". My local store that sells wire ripe and rigging sells 20 ft of the above with a grab hooks for 40.00. Most hardware stores or ranch stores sell Chinese and they want about 100-110 to duplicate the above setup. You can also get domestic stuf from Grainger but the cost will be 70-80.00 (you'll have to buy the chain and grab hook seperately and put them together.
Chain has it's place in your recovery aresenal along with your tow strap/rope, tree saver, winch line extention etc.
Don't forget good shakles. Again no Chinese, get Domestic Crosby's or Norwegian Van Beest. I don't care what people say about the Chinese stuff; I work in the energy industry and see Chinese and Asian stuff fail on a regular basis. They just don't have the metalurgy down to be trustworthy on important gear.
x2 on all of the above regarding chain. Yes, it does have it's uses....
...BUT, I've seen chain fail and I'd much rather be on the receiving end of a failed strap than a chain. Only use chain in limited circumstances.
Generally, I agree, no chains.
One situation where a chain would be better is if your only anchor for winching were rocks with sharp, jagged edges that could possible cut/wear through a strap.
Sounds like you have a winch - make sure you have a heavy pair of gloves to handle the cable with...
And we've seen bad things happen when cables break too. I'll bet that most times there are problems with chains it's due to one of two things: either using the wrong chain (too light, wrong specs or worn) or using it for something it is clearly wrong for (like in conjunction with a tow strap or rope where you needed more length). In a static situation where there will be no shock load a chain can work just fine. I'm not saying the chain should be the first thing you pull out of your bag of tricks; it should probably be the last. But it does have it's uses and if you're going to carry one buy quality chain.
