JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Snatch Strap
Old Dec 29, 2009 | 06:43 AM
Alf1096's Avatar
Default Snatch Strap
I have found a fairly good deal on a rugged ridge recovery strap. First off are these straps any good but more importantly what weight rating to get. I am torn between the 20,000 and the 30,000. I am leaning to the 30,000 because when I need it I don't want the strap to break. Also do any of you know a good place to buy d-rings for a goo price.
Suggestions and thoughts???
Old Dec 29, 2009 | 08:56 PM
Alf1096's Avatar
No opinions.....that's a first
Old Dec 30, 2009 | 12:47 AM
MBATF's Avatar
Sponsoring Vendor
Alpha Expedition
Most of the tow snatch straps sold by major companies are decent to very good straps. It is very unlikely a good condition strap(s) break during recovery. I have used both 20,000 and 30,000 lbs rates straps for many years and never had any problems.
Now as for D-rings. The true heavy duty green pin D rings are very pricey. They go for around $45 each, made in USA. Many of us are carrying the less expensive D rings which are sold by Quadratec, 4WD, Warn and etc. And their manufacture of origin varies (US, China & etc). They are sure up to the regular uses during recoveries.
Old Dec 30, 2009 | 05:50 AM
Newjeepster's Avatar
I picked up a 4 towing shackles for my Jk's bumper(s) for like $15.00 each & they have the green class 8 bolts through them. I got them at a tractor supply store locally. If you are going to be using them for vehicle recovery or any other heavy application. I recommend class 8 only. It's more expensive stuff. But you'll not have to worry about breaking anything
Old Jan 1, 2010 | 02:41 AM
32oz's Avatar
Snatch Strap? Is that a female version of a jockstrap?
(sorry couldn't help myself)
Old Jan 1, 2010 | 05:03 PM
Alf1096's Avatar
I can see your point and I did not think of that before ordering I went with the 30k
Old Jan 1, 2010 | 06:01 PM
Alf1096's Avatar
Originally Posted by Detn8RYellow
Was that a Snatch Strap or Tow Strap?
I have a 30k Tow strap, a 17.5K Snatch Strap, Tree Saver, Snatch Block and 10k Winch.. So I think I should be ready for almost anything.
I is a snatch strap. It was 60 bucks on ebay.
Old Jan 1, 2010 | 09:40 PM
JKRubi10's Avatar
Default Snatch vs Tow
Here is a great link on the ARB web site... they have a great explanation between the two and the advantages of each.
http://www.arbusa.com/Products/Tow-S...Straps/52.aspx
Old Jan 2, 2010 | 06:24 AM
Alf1096's Avatar
That is good info but not the question we are having a problem with it is whether to buy a 20k strap or a 30k strap.
Old Jan 2, 2010 | 04:35 PM
JKRubi10's Avatar
Default No Problem
Sorry about posting info that didn't address the question.. it just appeared that through the thread there seemed to be some confusion as to whether the discussion was around a tow strap or snatch strap. I am a newbie to this, but it does seem to be a bit of difference between the two (snatch strap stretches and uses the stored kinetic energy to aid in the recovery and the tow strap doesn't) If that is the case, maybe the weight loads listed for each strap to achieve the results may be different for the different applications... that is why I posted the link. It was helpful to me!
Thanks for the thoughts....
