Stability Control related question
I am trying to wrap my head around the features of my new Willlys. Let's say I go to the desert and I turn ESC entirely OFF in 4Hi. This will allow me more wheel spin in the sand. So far, so good. I might sometimes want to spin when getting stuck.
However, will the Brake Limited Differential kick in and stop the spinning that I actually want (and that I got by turning off ESC)? BLD can't be turned off after all:dontknow2: |
Traction control will be off, but the BLD will always be active. I think the difference is it won't throttle back by itself as it would if you hadn't turned the ESP off.
Here is a chart showing the various modes. http://i776.photobucket.com/albums/y...ps3ee650cf.jpg |
Originally Posted by ronjenx
(Post 4142155)
Thanks for the chart ! |
Originally Posted by aro
(Post 4142162)
So, on one hand I turn off ESC to allow for more spin, and on the other hand BLD kicks in and takes away some of the spin. It seems like those two features work against each other in this instance.But then.... I might be wrong, I really don't have experience with this... Thanks for the chart !
I have to admit, I'm on my mobile, so I can't tell the specs of your Jeep. If it is not a Sahara you very likely have an open differential, or you have a locker, which is an open differential until you lock it out. In either case, the BDL, (unlike that stupid traction control side of the system) is quite helpful. It is basically a much more advanced version of the old-school hand brake trick to force both wheels to spin rather than just one. |
I have a 2015 Willys, which comes with Trac-Lock.
I don't disagree at all that BLD is very useful, but there are those rare circumstances when you wouldn't want BLD to kick in. An on/off switch would have been helpful, but probably not worth the expense and complexity. I read that the ABS fuse might achieve that... |
(Post 4142206)
I don't disagree at all that BLD is very useful, but there are those rare circumstances when you wouldn't want BLD to kick in. An on/off switch would have been helpful, but probably not worth the expense and complexity. I read that the ABS fuse might achieve that... Happy Jeeping! |
It took a little hunting, had to come at it from google and then go through another forum to find the link, but this is the best write-up I have seen yet on it, and the one I followed. Super simple, can be done in an hour or two at the most.
The only thing is it kills all stability aids, including the ABS, The cruise control won't work either (I tried it just to see), and to bring the aids back on you have to flip the witch back to normal and then cut off and restart the Jeep. Hope this helps. https://www.jk-forum.com/forums/jk-w...riteup-260247/ Happy Jeeping! |
