JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
tire deflator
Old Dec 25, 2012 | 06:48 AM
onerichef's Avatar
Default tire deflator
Hi, I'm a newbie with an 011 jk,I will probably be using it mostly for beach running and it is my street cr(when I bought it I kept a car but enjoyed the jeep so much I sold the car) Any one have an opinion on deflators??
Old Dec 25, 2012 | 06:55 AM
Delux2769's Avatar
Staun are cheap and popular. ARB also has a set that's nice.
Although, I use a rock or knife.
JeepJeremy's Avatar
Staun Deflators are the standard IMO. Not cheap, but reliable and consistent.
Jeremy
Old Dec 25, 2012 | 07:05 AM
AK76's Avatar
Currie EZ Deflator work quickly... We used Staun on one side and Currie on the other. Currie finished just ahead, not that speed matters much. I also like the attached pressure guage.
Can't go wrong with either.
Old Dec 25, 2012 | 08:29 AM
TheTerminator's Avatar
I use Staun deflators and they work really well. They have 2 versions, 1 that goes from 6 psi to 30 psi, and one from 0 to 10 psi.
Here's a good deflator comparison:
Tire Deflator Comparison: Everything you wanted to know about airing down and more!!
Old Dec 25, 2012 | 08:43 AM
truckie515's Avatar
I made a home made tire deflator that does two tires at once. Got the idea from here, think I only spent 30-40 bucks. All you need is air line, you figure out how much (I have 2 ten foot sections.) a pressure gauge, 2 claw connectors, 1/2 turn valve, 4 port block. I even have it set up to air up two tires at the same time. I can deflate two tires from 38 to 20 in about three minutes.
Old Dec 25, 2012 | 10:21 AM
onerichef's Avatar
unbelievable!!! thanks everyone' I think I'm going with the Currie---- Love this forum!!!!
John
Old Dec 25, 2012 | 01:11 PM
k0260's Avatar
I use ARB's EZ deflator, essentially the exact same thing as the Currie. Works great, fast.
Old Dec 25, 2012 | 01:18 PM
Jeek.OlllllllO's Avatar
I dont like the curie one the first one i had was off by 10psi and then i got a new one and the second one is off by 6psi!
Old Dec 25, 2012 | 01:26 PM
OC-JK's Avatar
I use the currie one also. It's fast and easy. I wouldn't spend 30 bucks more for the stauns
