JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Tire pressure for 33" tires wheeling?
Old 03-30-2011, 05:17 PM
GreenJK07's Avatar
I usually air down to 20-22 psi while wheeling and I am curious with playing around with my pressure to get the best traction and performance, without pulling a bead (no beadlocks :(). Does anyone recommend a certain pressure for 33's? Is there a chart, or what pressure do you run? Thanks ahead of time for the advice!
-I have 33" bfg km2's.
Old 03-30-2011, 05:21 PM
Cdyspeed's Avatar
i run 18-19psi or so in my stock tires i ran 15psi in my 33's i never have a problem its really up to your preference and what your wheeling conditions are
Old 03-30-2011, 05:36 PM
GreenJK07's Avatar
Thanks! I wish there was a chart or guide out there. Next trip I will run them in that area and see how it works for me!
Old 03-30-2011, 06:27 PM
RevyJKU08's Avatar
Most trails I run 15 to 18 PSI but have gone down as low as 10 psi for snow/sand on my 33x12.50's
Old 03-30-2011, 06:29 PM
Croce's Avatar
Same here. Usually air down to 16 on stock sahara rims/wheels
Old 03-30-2011, 06:35 PM
Bone206's Avatar
I usually go 12-15 for my 33 duratracs on sahara 18 rims. No problems with beads or anything like that.
Old 03-30-2011, 06:41 PM
Nickit1981's Avatar
Default yep..
i have 33" pro comp xtreme mud terrains on 16" pro comp 8179s. Last time i wheeled i set them to 18 psi and it seemed too high still... gonna try 15 or 16 next time
Old 03-30-2011, 07:00 PM
bareass's Avatar
15 psi... has been fine for rocks
Old 03-31-2011, 05:09 AM
GreenJK07's Avatar
Ok so I've ben obviously keeping too much air in my tires, afraid to pull a bead. Ok going to go lower next run and see what we do. Thanks for all the comments and advice!
Old 04-01-2011, 08:24 AM
rexicon's Avatar
15psi is a safe pressure where you don't need to worry about losing a bead
Quick Reply: Tire pressure for 33" tires wheeling?
