Water/ Mud 1st time
#21
i just finished doing the breather extention mod and it was pretty simple. like stated above the transfer case line is in a difficult spot even took me a while to find it but once i got the line off and the new one on it was simple. for the rear diff i ran mine to the drivers side tail light insted of the pass. just for the fact that the drivers side only had that foam piece cvering the opening and on the pass. side there was a plastic cover that would have required some cutting. all in all it was easy and it took about 17' of 5/16 fuel line.
#22
There is no length that is too long. If you plan on really submerging your jeep then you'lll want to also install a switch inline with the fan. You don't want to get water in the bearings and have a bad day. Other places to waterproof would be between all connections. Put some dielectric grease in between all of them.
#23
I was told that water and mud gets in and can damage some components. I had a TJ that got the entire clutch assembly practically rebuilt. I bought the Jeep used, and I did press the clutch once to downshift when I went into a flooded roadway. Six months later, the clutch was jammed and the pedal would not go in. $$$ The mechanic showed me caked up mud and corroded parts which were apparently the cause.
#24
#25
Select 4LO before you go thru the mud or water. You won't need to depress the clutch to start. If you stall in the water or mud, Select your gear (1st/2nd or Reverse) without depressing the clutch and turn the key over it will jump start and start crawling without needing the clutch. Try it on a dirt road.
#26
Practice first because you don't want to be hitting high RPM's or speeds for any moderate amounts time while in 4LO if it can be avoided, and your first instinct while in a decent hole is to hit the gas to get out....
Hope this helps and if i'm wrong, somebody please chime in because then i've been doing sometihing wrong....
#27
Rear diff breather relocate
I just did this a few minutes ago, hope it helps....
9/32 vaccum hose with 3/8 vaccum connector. I added on without replacing factory hose. Zip tied it to E-brake line and frame and ran it up through frame into rear driver tail light so it would not catch on anything...
The connector is up in frame and I sealed connectors (aftermarket/factory breather) with electrical tape just for precautions...
I also left about a 1 1/2 feet of flex or more, just in case I need to modify it at some point...
#28
I would have passed out if I saw foamy chunk matter draining out of my trans!!! I still want a snorkel too
#29
10ft will be plenty to do both diff's. But you could pick up another 8ft you could extend your transfer case breather as well.
#30
I relocated front and rear diff, but not sure if transfer case is worth doing... The breather is attached to the back of engine block about 3/4 of the way up ( I believe it's trans breather). Where it sits should be fine. If you get that submerged, your now sitting in water that's about half to 3/4 of the way up your door. Is it worth it ?
