Weekly inspections
Before and after wheeling we all know how important it is to inspect the vehicle, but since I'm a newibie I would like to know what list of things to check and how.
Thanks!
Thanks!
Inspecting your jeep after off-roading is definitely a good idea to do! A good place to start is to check all your control arm bolts, shock bolts and if you have adjustable control arms, your jam nuts, to make sure they are tight. Put a torque wrench on them and tighten to specs. With all the vibrations that happen while on dirt, things can come loose. Also you probably should inspect your tires for any signs of damage (bulges, tears, etc.) If you have adjustable control arms with zerk fittings, you might want to go ahead and grease them while you're at it.
A summary:
1. Check bolts (control arm bolts, shock bolts, jam nuts, sway bar link bolts)
2. Inspect tires
3. Grease zerks
This is just a start and I'm sure others will add to the list.
A summary:
2. Inspect tires
3. Grease zerks
* Axles & Differentials - hubs, seals, u-joints
* Battery - clean terminals, check for damaged or corroded wiring
* Brakes - drums, rotors, pads/shoes, fluid, hoses, leaks, check e-brake, brake lights
* Belts & Hoses - look for cracks or bulges
* Body/Frame - look for cracks, dings, damage
* Cooling/Heating system - look for leaks, fluid levels, clean and repair fins, check hoses, thermostat, radiator cap
* Driveline/Transmission - inspect case and shifter, leaks, fluids, universal & cv joints, skid plates
* Engine - carburetor, or fuel injectors, spark plugs, wires, pumps, distributor belts; check for leaks and cracks
* Exhaust - muffler, tailpipes, look for general damage/rust
* Fluids - oil, transmission, brake, radiator coolant, gear oils, wipers, power steering
* Lights - headlights, brake lights, auxiliary lights; make sure they're aimed properly
* Nuts & Bolts - tighten axle u-bolts, lug bolts, nuts
* Steering - check alignment, fluid level, belts and hoses, pump and reservoir for leaks
* Suspension - springs, shocks, alignment, wheel bearings, steering linkage
* Tires - tighten lug nuts, air pressure, tread wear (including your full-size spare), look for cuts and missing chunks
* Wipers - check for wear, fluid level
Do you do that your self EVERY WEEK?
To much time.
what I do is lstn to her
she talks to me and tells me what's wrong with her
she would start clicking somewhere or dinging her pain away
It's longer than an airplane checklist
I look for leaks on the garage floor. Periodically check the oil for contamination. and get it serviced regularly.
If I have been banging the underside on the trail, I might be tempted to look at the damage.
Other than that, listen hope and prey.
