JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
What angles are too steep - clinometer
Old Dec 30, 2011 | 07:41 PM
Guardguy's Avatar
Default What angles are too steep - clinometer
Am setting up Smittybilt's iPhone Clinometer and I have to say it is the best app I have downloaded for offloading. I just need to figure out if the default angles are good for my JK.
--285/75-17 with 1.5" wheel spacers on factory rims
--2.5 inch BB on softer factory springs
--Soft-top, heavy duty bumpers and winch and usually a passenger
Defaults angles in the Clinometer:
--Roll 30 degrees warning, 45 degrees alarm
--Pitch up 40 deg. warning, 60 deg. Alarm
--Pitch down 50 deg. warning 65 degree Alarm
Old Dec 30, 2011 | 08:39 PM
jvandy50's Avatar
saw this too. crazy shit...there is literally an app for everything lol
Old Dec 31, 2011 | 05:07 AM
Blakspire's Avatar
This is one of those situations where the clinometer that you were born with, also known as the pucker factor, will outdo any iphone app. Clinometers are great for seeing your max roll/inclines, however, when it comes to the flop there are a variety of factors. Traction, speed, wheel speed, locked, unlocked, sway bar engaged or disconnected, fuel level, and the list goes on...
Best guage to use, by far, in any given situation, is YOUR rear end. If it puckers, its probably something that you need to reconsider, use great caution, or put the skinny pedal to the floor. Doesnt come with a battery either... Hopefully
Old Dec 31, 2011 | 05:14 AM
ronjenx's Avatar
Yup. Too many variables, even on the same Jeep from one trip to another. There is no certain safe angle to approach, thinking it won't roll prior to it.
Old Dec 31, 2011 | 05:33 AM
Tonka_yellow's Avatar
Get a fork lift and ruler. Measure till she rolls over. Then come back here and let us know what it was.
Old Dec 31, 2011 | 07:26 AM
rockbouncer's Avatar
A lot depends on how your tires are and if you have sway bar discos. A JK with discos will act different than one without, plus a lot will depend on how the vehicle flex's, like a two door will act different than a 4 door. Your question is probably going to be vehicle specific depending on your mods.
Old Jan 2, 2012 | 05:38 PM
Rockstar007's Avatar
You will never know the full limitations of your jeep if you dont push them.
Old Jan 2, 2012 | 06:47 PM
Whiskeypete's Avatar
i think the 'pucker' factor continues to getting less as you get older.
Old Jan 3, 2012 | 03:42 PM
arasco85's Avatar
Originally Posted by mpkelley20
I learned that 30 degrees is my Jeep's current limit. That's where my auto tranny says "hmm...think I will give up on you now. Hope you have your foot on the brake..."
Haha learned that as well. I heard a noise and was like a "awwwwww Shit!" Lol
Old Jan 3, 2012 | 03:52 PM
07greenjeep's Avatar
good luck with your apps, everything is electronic these days! Need to rely a little more on natural instincts. If it tilts a little and you get scared (warning), if it flips over, it was too steep of an incline (alarm).
