what gears are in 4 wheel drive LOW?? lots of power!?!?!?!
Just depends on situations. Rock crawling primarily relies on very slow and fairly accurate adjustments of the rig. Which can be difficult without low ratios (much much lower than a 3.21 axle and 3:1? case). If you aren't on the rocks, or hanging tires on obstacles, you'll be alright!
engine -> torque converter -> transmission -> transfer case -> axel gearing -> wheels
When you go in 4 L the transfer case and axel gearing will see a increase in applied torque not the transmission, torque converter and engine. The transfer case serve 3 functions on a Jeep: first it transfer power to the back wheels, second it transfer power to the front wheels and third it act as a second transmission offering 2 gear ration H 1 input turn for 1 output turn and L (rubi) 4 input turn for 1 output turn.
Here some ratio mathematic based on first gear 2.83:1 and rubi spec (for Sahara and X replace transfer case for 2.71 and auto axel 3.73. Note torque converter is set to 1:1 even if it impossible in first gear as I don't have a clue how to calculate it properly, but if any one can shine in and give us the math will be greatly appreciated)
use: engine -> transmission -> transfer case -> wheels
2/4 H example:
1500 -> 1500 / 2.83 -> 1:1 -> 530/4.1 -> 129 turns at the wheels
4 L example:
1500 -> 1500 / 2.83 -> 530 / 4 -> 133 / 4.1 -> 32 turns at the wheels
Since I don't need speed most of the time on the trail but torque for overcoming obstacle without the need to ram it I use 4L. Also I observed for equal speed the higher gears look to be keeping the transmission cooler as I think the transmission pump is running out of the output revolution of the transmission but do not have any proof.
It has been my experience that going into 4lo reduces the automatic transmission temperature. I can watch it on the gauge.
In 4hi, on the trail, the tranny may not come out of 1st or 2nd, therefore the torque converter never has the opportunity to lock up.
Being in 4lo allows the tranny to make it to 3rd, and if you have the O/D off, the torque converter can lock up, at least some of the time.
I can see the temps go up in 4hi, and go down in 4lo.
Also, most of the time, turning on the A/C will reduce temps a little more.
