JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
What GPS are you using while off roading??
Old Aug 27, 2012 | 01:01 PM
Signal 20's Avatar
Default What GPS are you using while off roading??
I am looking to buy a new handheld GPS to use while off roading. I have been looking at the Garmin Oregon 450 recently but havent been able to play with it in person, just pictures on the internet. I also want to be able to use it while hiking in the Colorado area so I would want something that has trail map capabilities. I tried to use my Garmin Nuvi GPS last time I was on the trail, however it is just a road driving GPS and basically said "driving on dirt road" for the whole day. What are you using and why do you like it?
Old Aug 27, 2012 | 03:40 PM
Since 1941's Avatar
I have a Garmin 76 csx that is a great all around hand held unit. It's an older model that I've had for over 5 years, but it does everything I need.
1. Sensitive antenna that works well in the woods.
2. Waterproof.
3. It floats.
4. Lots of 7 1/2 minute quad maps available.
5. Built in pressure altimeter/barometer.
6. Built in mag compass,
I would imagine that the newer Garmin units would surpass those capabilities, but the above may be helpful to you as a point of comparison.
Alan
Old Aug 27, 2012 | 07:34 PM
Radioman's Avatar
Veteran: Navy
I use a Oregon 450 and am pleased with it's performance. I added the topo maps for the western US and I rarely find a trail that is not on the unit.
If you have been looking at them you know its specs and capabilities so I will not repeat them here. I do recommend a power cord however.
Old Aug 30, 2012 | 01:12 PM
Camojeep's Avatar
I use a Garmin Oregon 450T for Geocaching and a Nuvi 500 for jeeping and off-roading. The topo in both is pretty good
Old Aug 30, 2012 | 01:32 PM
bobberdown's Avatar
I use the Garmin 450T as well, I absolutyl love it. I installed the TOPO maps as well. I like being able to do my research and maping on my home computer, and down load to the hand held. I use it to scout new hunting areas as well, as I identify areas I would like to check out after looking at the topographic maps, satallite imagery, and then am able to upload my waypoints into it from my computer. Very easy to use handheld, with a good battery life as well. I have a heart rate monitor as well, to see what kind of a work out I gave myself when I am out running trails and such too. YOU WONT GO WRONG WITH ONE!
Old Aug 31, 2012 | 08:12 AM
ChrisJ's Avatar
I'm using a Garmin GPSMAP 60CSx. I just recently put the northwest topo map on it which I'll be using for the first time this weekend, so I can't really provide a comprehensive review just yet. I'll let you know how it works out, though.
Old Aug 31, 2012 | 05:55 PM
bobberdown's Avatar
the garmin etrex is also a good candidate, however the oregon is a much better unit with a bigger screen.
Old Sep 8, 2012 | 06:59 PM
BAJK's Avatar
I use my iPad with a Bad Elf GPS chipset. The screen is large and it's easy to use. I have it Ram Mounted to my roll cage on the passengers sides of the cab. I love the set up and I can use the iPad for other things as well.
DE
Old Sep 8, 2012 | 07:52 PM
EdmontonSparky's Avatar
iPad 2 with the Memory-Map topo app and a Bluetooth Dual Gps antenna. Magellan Roadmate app on road. Works great.
Old Sep 9, 2012 | 11:31 AM
JTE's Avatar
JTE
How is the accuracy of that Dual, also will it work with a wi fi only iPad? Do you have the iPad mounted?
