who here has actually used a hi-lift as a winch
#21
I have used a hi lift a a winch on several occasions and I found that a synthetic strap is needed, other wise you just have alot of stretch and do not get the full potential of the hi lift, another thing you should have something to tie back the vehicle if you need more than 1 length of the jack or the vehicle may slide right back into its original spot.
#23
Let me ask you this, If you're stuck and can't pull yourself forward with a winch, or the battery is dead, and there is no chance someone can get to you to yank you backwards, will you remember about the $200 you could have spent for jack and chains that would most likely get the job done?
#24
( I have used one to pull out a ford 1 ton crew cab backwards. It sucked, but it worked. Now he has a 12k winch that paid for itself the first time he got stuck and winched out in 3 minutes instead of four hours, but that hi lift is still in the back.)
#27
#28
#29
a hi lift jack should be in every off-roaders budget... Improvise on accessories
go to companies with cranes and see if they have slightly damaged lift slings, they are good for 25,000lbs and get deemed out of service for just minor damage. I went and they unload a shit load on me.
I went and bought a shackel that fit in the top hole on the hi lift bar and then hook another to the lift part add muscle, stamina beer, and friends willing to laugh at you(and be roped into taking turns) and you will be home before dark
