JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Which winch??
Old Nov 9, 2013 | 09:58 PM
kmrtnsn's Avatar
Originally Posted by ShutterBug
Living in a climate that gets lots of snow, a recessed winch doesn't make sense. I would also worry that the moisture that gets into a synthetic line would likely turn it into a giant ice cube when to got cold. So I am likely to get cable over synthetic.
What are some opinions on the Quadratec line of winches? I like the 9500i myself.
A cover for your winch to protect from moisture and UV is a good idea, regardless of clime. Synthetic winch lines do not absorb water any more than twisted steel cable does making ice and freeze a non-issue.
Old Nov 10, 2013 | 06:55 AM
Nwapache's Avatar
A warn Zeon 10s is the perfect jeep winch IMHO. A winch is like a first aid kit, you'll use very rarely, but when you do, you need it to be perfect. Synthetic is the way to go, in the last 3 years I've found almost no factual information that concerns me about its use. 12k is overkill, esp with a 2dr, and if you're concerned about having enough oomph to do the job, pack a snatch block. You'll halve your line speed but double your pulling power.
Old Dec 9, 2013 | 03:59 PM
OldHarleyGuy's Avatar
I am looking to get my wife a Warn winch to go with the Warn Elite front Bumper I am getting her for Xmas and want to add the Winch at the same time for Birthday gift and trying to decide on a Warn M-8000 vs Warn VR-8000 , I know see May never need if but that's about all she needs to complete her JK after lift and tires any suggestions on if there's a big difference between the 2 ?
Old Dec 10, 2013 | 08:31 AM
Rob 12B1P's Avatar
In my experience its easier to damage a steel line than a synthetic. Not every recovery is going to be a straight on pull and this will cause the line to ball up on one side and/or sometimes cross itself. This can damage the line causing pinched and bird caged areas. Since I switched to snynth I haven't had a problem with this. I just watch the line and make sure its not going to run across anything that will abraid or cut it.
Old Dec 25, 2013 | 11:46 AM
Rubicon John's Avatar
Over the years, I've used both cable and synthetic lines and both will get the job done. However, I do prefer the synthetic lines for safety and weight savings.
During the last snow storm a few weeks ago, I used my synthetic line without any worry about it being frozen or related moisture issues. In fact, knowing that ships in salty and snowy conditions primarily use synthetic lines really puts that argument to rest.
Old Dec 25, 2013 | 12:26 PM
kmrtnsn's Avatar
As you illustrate, there is a misconception of many that synthetic line absorbs water, it cannot and does not. In fact, remove the hook and most synthetic winch lines will float. If it can't absorb water, it can't freeze.
Old Jan 13, 2014 | 03:12 AM
kdubflint's Avatar
So i've worked in the Maritime industry for seven years now both in the gulf of mexico and in the northern atalntic (as well as in the south china sea) and from experience i can tell you that "synthetic" lines can freeze. just because they dont absorb the water in their fibers like manila lines do, doesn't mean that they cant hold moisture in between the strands; especially if its just wrapped around your winch. Trust me, after hours of beating on synthetic lines with a sludge hammer just to get them somewhat what flexible in the dead of winter i can attest to the fact that they can freeze. The most important thing to do with synthetic line is to keep it out of the sun, too much exposure will cause it to dry rot (become hard and brittle).
I believe that most of the winches out there have a type of spectra or kevlar line which is stronger than steel per weight. these will float, however if for some reason you come across a winch with nylon or polyester i would definitely steer clear. these two lines are strong howver they do not float and the tend to have a lot elasticity to them. Again, i haven't seen any winches with those on their so i wouldnt worry about that too much, just some free knowledge
I like synthetic lines a lot, especially for safety reasons. the spectra and kevlar lines are designed to just fall and not have the snap back that typical wire or other synthetic lines are known for. when in doubt go with what is safest.
