JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Winch cable kink..
Old Jan 29, 2024 | 04:30 AM
Simikilr's Avatar
Veteran: Marine Corp
Default Winch cable kink..
So when I got my new winch and went to unspool it and reel it back in under tension, for the first couple seconds I accidentally hit "out" instead of "in". So it started wrapping up the wrong way. Now it wasn't under tension yet, but it did give the cable a slight kink right at the beginning where it mounts to the drum. Since it's at the VERY beginning of the first wrap, would this be OK or should I replace this brand new cable? My jeep is about 4,000lbs and the winch is a 12k (over kill I know).
Old Jan 29, 2024 | 12:22 PM
Jay2013jk's Avatar
Veteran: National Guard
Community Favorite
IMO, contact the winch mfg. Run this past them, they should be the experts. you might find this informative:
Old Feb 6, 2024 | 12:53 PM
Dat's Avatar
Dat
Personally I wouldn’t worry about it, wind it up and forget it, you should never unwind past down to the second row anyway, if it’s on the first row (on the drum) you are good to go,
