JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Winch size
Old Feb 23, 2011 | 06:12 PM
Foosh's Avatar
Default Winch size
Anyone have any problems self recovering a 4 door with an 8,000 lbs winch?
Old Feb 23, 2011 | 06:15 PM
shockwaveaz's Avatar
I don't have a for door but an 8K pound winch will be fine. Just carry a snatch block in case you need more pulling power.
The "experts" say 1.5 times your weight.
Sent from my PC36100 using Tapatalk
Old Feb 23, 2011 | 08:36 PM
AK4Dave's Avatar
Indeed....sometimes snatch blocks make all the difference in the world...
Old Feb 23, 2011 | 08:43 PM
BKGM Jeepers's Avatar
No problem with an 8K winch. Snatch blocks double that. You're good to go with it!
Old Feb 25, 2011 | 07:52 PM
4fox's Avatar
Yeah, thats what I plan on doing also.
Snatch block gives you a 2:1
Old Feb 27, 2011 | 09:03 AM
Harbourone's Avatar
Snatch blocks are good if you have enough line to use it. I've been nearly out of line when I got to a pull point, so a snatch block would be useless.
Buy as big as you can afford within reason. I've got a 10.5k and it barely pulled me out. I would have bought a 12k if I had the $$$.
Old Feb 27, 2011 | 12:28 PM
Foosh's Avatar
Alright, I'll make sure I keep a snatch block with me. As far as going big, I was limited by size to no more than a 9,500 lbs winch per manufacturer suggestions. So, I have two 8,000 lbs smitty built winches. One on the front bumper and one on the rear bumper.
Old Feb 27, 2011 | 09:25 PM
Wth did you get in? .... Maybe it was your battery or the winch you have draws big power bc I pulled a heavy ass H2 out of a mud pit burried to the doors. It pulled the front through the ground because of the angle I was at. I even had to chain myself to a tree! This was on a Warn 9.5XP!
Old Feb 28, 2011 | 04:53 PM
Harbourone's Avatar
Was stuck in clay up to the passenger door handles with my drivers side wheels barely stuck at all. Had to pull at a 30* angle to get out and on high ground. Pulling anything out of snow is a simple pull as there is no drag or suction from a snowbank.
