Winch synthetic line likes or dislikes.
I've been wheeling and winching for quite a while and ran rope for 9 years on my tj, without failure. The secret is keeping it covered so it doesn't suffer UV deterioration. After watching a steel line fail during recover and severly damage the jeep it was on, I won't run steel line again. Like everyone says, it's basically personal preference. I am with rope again on my JKU. 5 years of amsteel blue and it still works like the first day I bought it. I keep it covered with a Warn neophrene cover until I need it and it works just fine - plus I know I'm not putting buddies in danger by using it. Remember that clearing out make make for a safer recovery but with steel line d-rings can become projectiles and fly quite far...
Winch rope
I am a rigger by trade I have been involved with every aspect of lifting 500 ton+ loads, I like steel on the drum, synthetic for attachment points, steel is more forgiving if it comes in contact with rough objects. That said synthetic is got to be much safer for the average wincher, in my experience when someone is stuck everyone wants to get involved with helping & they might not have the experience to reckognize the dangers,so synthetic could help eleminate one of the hazards. I will run my steel till it becomes non servicable and then I will consider the benifits of changing to synthetic.
A Syn line will live longer if covered when not in use, to prevent prolonged exposure the the suns' UV radiation.
Oops... Now I see that it already been said...
I definitely agree with that statement.
But how it was explained to me was the tension put on to the line and released over some pulls( don't have an accurate number to throw in there) would stretch out the line causing it to lose strength. Now whether or not that is true is up to you to determine. Again this isn't from my personal real world experience. Just trying to add some knowledge to be thought about.
I got my winch with a synthetic line, never used steel before, so I can't comment. I love my synthetic. My friend with an arctic slid into a ditch yesterday on his own property (during the storm, he has a large property and was plowing) and needed to winch himself out. Went to unspool the line, bam, tangled with layers sinking underneath others....so, it was useless. Glad I don't have that problem. The tiny benefits of steel are outweighed (IMHO) by all the benefits of synthetic.
Similar to my previous post, from what I understand a synthetic line has a limited amount of pulls before the line becomes frail. Now I've never run a synthetic line before so this isn't first hand knowledge but has been passed on to me by a few people who wheel hard and wheel often.
Another vote for synthetic. Weight is negligible compared to the steel cable and also a lot easier to spool. So, this will go a lot easier on your suspension and gas mileage.
Luckily I never saw any synth break but I read they are a lot safer than steel in case it happens because they do not snap and slice heads off.
Only thing is that you should keep them protected from UV rays but this is easy with a cover, which will also protect your winch.
Not entirerly true, you have to look outside the box. Tug boats for one use synthetic line and in a commercial application they are pretty rough on towing and mooring lins putting a lot more dynamic load on them than we as jeepers ever will. When I waas in the military we swaped all our hoisting/lifting slings and mooring lines out for synthetic for the same reasons as previously mentioned - but yes you have to take care of them.
