Winching question -- using reverse
#21
Hopefully that is a lesson that the Dodge driver will learn from. Too bad for the other guy. Trying to be the nice guy is great but if it is at the expense of your own vehicle maybe you should think about it first.
I tried to help out a guy once that was hung up and before I damaged my winch or his vehicle I had to just tell him that I couldn't help him out. I felt bad but he was pretty understanding and luckily he was able to get someone with a heavy duty rig to pull him out.
#22
Sponsoring Vendor
Alpha Expedition
Alpha Expedition
#23
Wraithyjeep nailed it when he said:
neutral 4lo emergency brake on
locked front and rear if you wish.
A couple other thoughts to consider:
Winch with your hood raised (it can save your life and your windshield).
Use a strap if possible. It's faster and when done right (low speed/steady momentum) runs less risk of injury to you and your rig.
Remember, just because a "trick" works, dosen't mean it will always work, or that it's good for the equipment.
Think long and hard about who your pulling. I help just about every person I can, but it sucks to break equipment and be left with the repair bill to replace YOUR broken stuff!
#24
That's a good rule, and I agree with the principal, but I usually feel bad for the guy. Sometimes it feels like charging him is like kicking a guy when he's down. I just chock it up as a bummer and hope that I'll be the guy to get helped in the future!
#25
and after all isn't the whole point of getting the guy down is to beat the crap out of him?
#27
Former Vendor
I feel it's your equipment and you need to need to know it's limits. You can stop the winching at any point if things are going long. Additionally, if your line isn't properly cared for (especially important with synthetic) then it could break and the recoveree shouldn't be responsible.
At the end of the day you really need to think twice before recovering someone's vehicle. Think about the situation and what consequences can occur. Make sure there's a verbal agreement with at least one witness, and make sure the recoveree hooks his own vehicle up.
#28
to add to the last comment about letting the stuck person hook up their vechicle yes but remember that you are recovering them so you have alright to recommend something else if you feel its not safe if they dont agree with you disconnect and leave
#29
Former Vendor
I'd like to agree with it on principal, but it's hard to justify. My thought is that it's your equipment and you take the risk by using it. The exception to the rule is that if something is required because of the recoverees situation that damages equipment (e.g. no tow points and attaching the strap to a leaf spring causes the strap to get fraid or damaged).
