37" BFG KO2 Installed
#31
They probably do, but they will still weigh 10+lbs more than 37" KO2's which is what I want avoid so I don't need as many axle upgrades or new gears. These will be a nice bump over my 315" Duratracs which measure 33.5". I will be running MCE flat fenders, 37" KO2's and 2.5 MC lift.
#32
#34
My Fierce Attitudes 35's are a true 35" I'm stepping up to 37s and expect a true 37... leaning towards mud grapplers
#36
#37
I was on my lunch break and thought I'd do a quick trail run
I crossed a small creek and stopped in the middle to see how they would do. As expected the tires are less than stellar in the mud and don't clean out well at all like most all-terrains. After some boring around I wasn't able to get enough bite to pull myself up the small bank and had to winch out
Not what I had in mind
Attachment 604746
Clogged up
Attachment 604748
Back to work...
Attachment 604747
Cleaned up after (Silver is on 37" Toyo MT's)
Attachment 604745
Attachment 604746
Clogged up
Attachment 604748
Back to work...
Attachment 604747
Attachment 604745
I am looking at upgrading from a Cooper STT in 315/75r16 to these in 37x12.50x17 ( wheels as well; staying with level 8 strike 5s) and am disappointed in your mud testing; may I ask if you had aired the tires down on your lunch break prior to attempting the little mud bog/creek you were unable to clear out of?
I was initially just like you and wanting to sacrifice the MT in 35" ( actually about 33.5 now that I am at 22k miles on the Coops) for this in a larger diameter and after reading about the 37s being only 68lbs, I was psyched. But, I wheel hard in both rocks and ( unfortunately in S.Eastern US) mud that I cannot always avoid getting to the rocks. I would very much disapprove if I had to winch myself out of such a small hole as you did . Now, your post is making me have 2nd doubts about this tire. I wonder what the next closest weight to this would be .... thanks for the information on this as you may have saved me massive disappointment. All the reviews imply that these are better in Mud that the old KOs but I do know that unless you deflated to around 10-15psi , then the mud hole creek would likely have resulted in you not taking advantage of the wider footprint and just dug yourself into the hole. Had you aired down or just went at that mud with 30psi on the KO2s?
thnks
#38
I am looking at upgrading from a Cooper STT in 315/75r16 to these in 37x12.50x17 ( wheels as well; staying with level 8 strike 5s) and am disappointed in your mud testing; may I ask if you had aired the tires down on your lunch break prior to attempting the little mud bog/creek you were unable to clear out of? I was initially just like you and wanting to sacrifice the MT in 35" ( actually about 33.5 now that I am at 22k miles on the Coops) for this in a larger diameter and after reading about the 37s being only 68lbs, I was psyched. But, I wheel hard in both rocks and ( unfortunately in S.Eastern US) mud that I cannot always avoid getting to the rocks. I would very much disapprove if I had to winch myself out of such a small hole as you did . Now, your post is making me have 2nd doubts about this tire. I wonder what the next closest weight to this would be .... thanks for the information on this as you may have saved me massive disappointment. All the reviews imply that these are better in Mud that the old KOs but I do know that unless you deflated to around 10-15psi , then the mud hole creek would likely have resulted in you not taking advantage of the wider footprint and just dug yourself into the hole. Had you aired down or just went at that mud with 30psi on the KO2s? thnks
#39
I just made the bump up to 37's from 35's. I wanted a small 37" lighter weight all terrain tire so I went with the BFG KO2. I thought I'd post some pics for reference since there isn't a lot out there yet for the 37's. I was running a 2.5" lift with small 35's (BFG KO) and just recently installed an AEV 4.5" so I wanted something that would fill the fenders a little more without losing a lot of power. The KO2's are exactly what I was looking for size wise, but would probably be disappointing if you wanted a true 37. They run small like most BFG's
About 68 lbs
Attachment 601965
Unmounted compared to my old BFG 35's (measured 33.5")
Attachment 601966
Unmounted 35.5"
Attachment 601967
Mounted just below 35.375"
Attachment 601968
Rearview
Attachment 601969
About 68 lbs
Attachment 601965
Attachment 601966
Unmounted 35.5"
Attachment 601967
Attachment 601968
Rearview
Attachment 601969
It's interesting that BFG's site shows that the tire height at 36.5 and just a little more in weight.
#40
Attachment 607127
Attachment 607127
I was primarily disappointed with the mud handling ( I know , it is an AT) but really would like to know if the OP had aired down prior to getting stuck.
The images sure appear to not show any deflation.
I may go with my true desire and just splurge on the 37" Falken M/T in comp material at GenRight ( if they have nay left) . That is the tire I was hoping to get but it seems Falken has no desire to get the commercial version to market anytime soon.
I was going to get the KM2 in the 345/75r16 for my existing wheelsize but it is a Unicorn size that no one has seen available ( I know vendors on other forums) since 2010 or there woulkdnt even be a question. They just fdon't produce 'em.
I didnt mean to hijack the OPs thread
sure wish he would reveal if he had aired down before his stuckness
