37" BFG KO2 Installed
#81
looks great, are those pro comp 7069s? I might be running that same setup if I decide on these KO2 in 37s. Really looking for longer term reviews before I pull the trigger. I am running KM2s right now and I like them but I am ready to step it up to 37s finally and want some light ones with my D30 up front. look forward to seeing more reviews on these tires
#82
#83
Thinking about upgrading from my 33" toyos to these 37 KO2's running hurricane flats could I get by with an aev 2.5 lift or would I be better to just go for the 3.5 in lift? I want some room for articulation and don't want rubbing
#84
#87
Running 37s on 4.10? You *will* feel the need... and depending on where you live (elevation and/or very hilly) you might consider 5.13 or even 5.38. I live at higher elevation and run 37s on 5.13 with a stick shift - wishing i went to 5.38 instead.
#88
My jeep is a 2014 with an auto so i think that would be to much gear. My 2012 with the auto / 4.10 combo was pretty good with 35" Cooper STT tires (same weight as 37" ko2). I know the extra tire height will affect the gear ratio more though.
#89
I have a 2012 JKUR Auto. with 35s and 4.10s I thought it wasn't too bad. Put on 37" BFG Krawlers and regeared after only a month. Hated it. Freeway on ramps gave me problems and don't even get me started with having to downshift at highway speeds in order to get more speed on overpasses. I went with 5.13s but I think 4.88s would be just as good. 150 rpm difference between the two
