609 Axle
Here is a few pictures of the new Currie F9 Fabricated Housings for the JK. I will post pricing soon!!!!
http://www.currieenterprises.com/ces...E.aspx?id=3414
lots of questions.....
most importantly, are you still going to be making the rockjock60's for us?
Pro's and Cons from post number 5.
For those of you that dont know what a 609 is...
Dana 60 knuckles
+ Ford 9" third member and/or center section
= 609
EDIT:
WHY: You get the best of both worlds. One Ton strength on a commonly available Axle Housing
ADVANTAGES (Over a complete Dana 60 Front axle):
Availability. Dana 60 Front axles are getting scarce, and are very expensive new.
Ground clearance. The 9" hangs 5-7/8" below the axle centerline at its lowest point. The Dana 60 is 6-1/4". The custom "High clearance" Currie housing pictured above is trimmed to 5-9/16". A Dana 44 is 5-3/8".
Weight. The Ford 9" is lighter than a Dana 60.
Drop out center section. The 9" is very easy to set up gears and change the third member out.
Availability of a High Pinion third member. This axle utilizes a "high pinion" arrangement where the drive shaft enters far above the axle centerline. Up out of harms way. A Dana 60 was available with a High Pinion in Ford F350's. Expensive hard to find, and the differential is on the wrong side for a Jeep CJ.
Cost. 9" housings and components (gears, lockers etc) are priced significantly lower than Dana 60 (and even Dana 44) parts.
Dana 60 knuckles
= 609
EDIT:
Yes we will continue to offer the Rock Jock 60's
A Few Pros and Cons of the 9"
Pros...
-More gear ratios available than any other axle
-Lost of Locker Options
-Modular design makes for easy service
-Lighter than a 60
-Fabrication Friendly, can weld custom brackets anyware on housing
-Hi-Pinion 3rd members available for great driveline ground clerance
-Easy trail repairs
-Higher ground clerance than a 60
Cons...
-Low Pinion design hangs lower that any other low pinion axle
-Higher Cost than a 60
-Hi-Pinion 3rd member Gear Availability (lack of ratios)
Pros...
-Lighter than a 60
-Easy trail repairs
Cons...
