Atlas Four Speed T/C
No, I went with the 5:44 instead. If I need to get out and take a leak, I'll just stop the Jeep instead.
Seriously, I don't think I'd ever use the 10:1 while I think the 2:1 could come in real useful in the snow.
Hadn't even heard of a support ring until your post. I don't think the weight difference is that much between stock and the Atlas, but I'll definitely put some thought into it. As far as anything else, I'm going to rebuild my Reel drive lines and put in some greaseable u-joints. Never can seem to get those needle fittings to accept any lube. There's some interesting adjustments to the wiring so the JK knows it's in 4wd and so that it only shifts to low when in neutral. Other than that it looks pretty much plug and play.
[/IMG]
