Body Lift Pix
Old Jan 11, 2010 | 11:25 AM
klutz1001's Avatar
Default Body Lift Pix
Hey yall,
I am thinking about adding a body lift and wanted to see some setups with one already on it... thanks in advance!!
Old Jan 11, 2010 | 04:38 PM
dlincoln91's Avatar
i have the roughcountry 1.25"
sorry this is a bad pic
Old Jan 16, 2010 | 02:19 PM
09bbjk's Avatar
Semi thread Hi-jacking in progress... Did you run into any issues with the brake lines adding the 1" body lift in addition to the suspension lift you have already, such as having to swap the lines out with longer ones. Sorry if it seems like a dumb question, but I am halfway around the world right now and can't get under my jeep to look at it. Thanks, and both of your jeeps look really nice.
Old Jan 16, 2010 | 05:42 PM
crazyhorse02's Avatar
im pretty sure the brake lines are frame mounted so by moving the body up wouldnt effect the brake lines or any other part of jeep..only concern would be the shifter boot if you have a manual..someone correct me if i am wrong
Old Jan 17, 2010 | 06:21 AM
sahara-07's Avatar
hi thats mine all take a bether pic of it but it has 2.5 coil spacers and added .5 in to the front . after that added 2'' body lift .
i made some brackets for the rear brake just in case with the flex .
and outo transmision you dont need to do nothing for the shifter but manual yes ..
Old Jan 17, 2010 | 09:26 AM
Slightlymodified's Avatar
I have 3 1/2" suspension and 1" body running 37" BFG'S
Old Jan 17, 2010 | 12:56 PM
09bbjk's Avatar
Awesome, hey thanks for the response I wasn't quite sure, I am planning on adding a body lift and eventually moving up to 37s when I can afford axles, but I didn't want to enact the plan and not have the appropriate items to complete the install when I get back. Good looking JEEPS by the way.
Old Jan 19, 2010 | 05:50 AM
klutz1001's Avatar
sahara... i would love to see some more pix..... i havent seen a 2" yet! but bump for more pix from anyone...
Old Jan 19, 2010 | 01:42 PM
NICHUGHES's Avatar
Here is mine I have a RE BB and the 1.25" Rough Country body light with 33" tires.
Old Jan 19, 2010 | 04:11 PM
topdog1308's Avatar
Nice rides
