custom antenna bracket!
Old Sep 4, 2008 | 04:02 PM
rubiconjack's Avatar
Default custom antenna bracket!
Just got it on a little bit ago. John did some cutting and heating up and manipulating ......
it works ... lets hope! Still have to get the radio hooked up ... but I will post pictures in a little bit of my rear end! It is where the stock tire carrier used to be.
Old Sep 4, 2008 | 04:57 PM
Ewok's Avatar
I CAN FINALLY DO IT!!!!
Old Sep 5, 2008 | 05:25 PM
Default pictures!
The edges need to by sanded down a bit and need to paint it black still .. but ya get the idea!
Old Sep 5, 2008 | 05:45 PM
JMP8562's Avatar
NICE AND CLEAN DID YOU PUT A RUBBER GASKET OR RUBBER WASHERS BETWEEN THE BRACKET AND BODY
Old Sep 5, 2008 | 05:59 PM
northsidejeepin's Avatar
That looks really good, but how strong is it when the antenna is bent down?
Old Sep 6, 2008 | 03:21 AM
pearl-drum-man's Avatar
Looks good! I do wonder about long-term strength near the bend. Did you consider welding it up a bit to beef it up?
Old Sep 6, 2008 | 03:34 AM
2drREDROCK's Avatar
I like it very clean
I might make some thing like that at work
Thanks for an idea the pics are great
Looks like it would work out great with the OR-FAB carrier I'm waiting for
Old Sep 6, 2008 | 05:21 AM
BIGJ's Avatar
not bad lookin i guess, but will it bend if you get it caught on something??
Old Sep 6, 2008 | 06:33 AM
I have no idea .... we will find out ... it was just so I had one to get ahold of everyone ... might look into welding some more pieces to strengthen it ...
did not add washers ... will probably add sum rubbers one when I get back from wheeling this weekend ....
it works though .... for now. :
Old Sep 7, 2008 | 04:02 PM
okay .. update ... after some wheeling at Evans , which is known for the tight trails and body damage ...
It held up to trees and stumps pushing and pulling on the bracket! Guess in time we'll tell.
