Dynatrac Pro Rock Brake Upgrade Kit
Need Help
What brand are Dynatrac Brake Upgrade kit is in terms of twin Calipers and Rotors. Can some one post details of the thickness of the rotor and specifications of the twin Calipers. Also does the Stock Master Cylinder can handle large twin calipers in the front. |
Don't know about the actuall size (measured) of the thickness of the rotor but I will tell you that it is VERY large!! I have the big brake upgrade kit and it is amazing! I can stop the Jeep with 37" tires better than it did stock. My master brake cylander is working just fine...
I recommend the big brake and stub hub kits!!! Well worth their money, besides when you are buying proRocks don't worry about couple hundred dollars when you are spending sevearl thousand.. :dontknow2: |
Do you know what brand kit is the rotors and calipers? That will really help.
Also If you dont mind can you please tell us what is the thickness of the rotor? Is you brake pedal spungy or soft or as good as stock? |
Originally Posted by JK07
(Post 1542938)
Also If you dont mind can you please tell us what is the thickness of the rotor? Is you brake pedal spungy or soft or as good as stock? Don't know the brand...ask Dynatrac Don't know the thickness either...sorry but I know you have to run a minimum of 17" wheels to clear the rotors Brake pedal is better than stock...very firm and stops VERY quickly. |
1 Attachment(s)
Can not see the brand.
But the thickness of the rotors is 1,10" |
(Post 1542813)
Need Help
What brand are Dynatrac Brake Upgrade kit is in terms of twin Calipers and Rotors. Can some one post details of the thickness of the rotor and specifications of the twin Calipers. Also does the Stock Master Cylinder can handle large twin calipers in the front. What did Solid Say? We did a lot Of R&D with DynaTrac on that brake set up.and they work great. I belive you can purchase all of that from DynaTrac ask for Steve (1 714 596 4461) Mel |
They are made by TRW an it's a 03-06 maybe later dodge 1500 caliper and rotor. You need to use dynatracs maybe solid knuckles and dynatracs caliper mount. This the the same brakes I am using on my prorocks. Pm me if you need a set. I have a extra set of calipers and rotors for this conversion.
MAN thanks for your help. PM Sent
Originally Posted by Got4wd
(Post 1546967)
Mel
I aksed you to sell me the Brake Upgrade Kit and you refused to help. I also Called Dynatrac spoke to Rob and Steve and they refuse to sell beacuse I am using Solid Axles. We did a lot Of R&D with DynaTrac on that brake set up.and they work great. I know you did a lot of research with Dynatrac thats why I asked you if you can sell me the Kit or atleast tell me what Dodge 1 Ton Van these calipers are from so I can purchase from somewhere else.
Originally Posted by Evolution
(Post 1544503)
What did Solid Say?
Your Bio says you have Solid D60's. Did you call them with your problem? Just curious what their answer to this is. I'm also running Dynatrac D60's F&R with their brake kit. Works really well. Not spongy at all.
