Evo Coilovers with lift kit
Old Jan 5, 2009 | 03:28 PM
asjackman's Avatar
Originally Posted by Robar
First you won't need your factory springs, shocks, or BB pucks, because the coil overs replace that. In fact your stock spring and shock mounts are cut off in order to install the coil overs.
Second is that the way it was explained to me is that if you use the stock control arms then you have to cut the control arm mounts for cam bolts. It is much more advisable to purchase adjustable control arms.
I did forget about pinion angle. I think I will go with a short arm kit and the Evo coilovers then.
Old Jan 5, 2009 | 03:33 PM
jayrav's Avatar
Here is an idea for you:
ORE front coil kit
Teraflex LA kit
Teraflex high steer kit
Teraflex 4" rear coils
Teraflex rear shocks from the 6" lift kit
This will be my set up with in the next few weeks. I currently run a 3" teraflex lift kit. I'll be selling pretty much the entire kit except for the rear trackbar bracket. That I'll sell in the summer when I get the rear EVO lever kit
Good luck!
Old Jan 5, 2009 | 03:49 PM
Ctimrun's Avatar
ORE front coil kit
Teraflex LA kit
That is very close to the setup I started with when I first went with the coilovers in front. You will be very happy with that setup!
Old Jan 5, 2009 | 04:00 PM
asjackman's Avatar
ORE front coil kit
Teraflex LA kit
Good luck!
Will I need longer sway bar links? Will the rear trackbar bracket that came with the 2.5" TF BB suffice or should I get an adjustable rear trackbar?
Jeez, why do I have so many questions?
Old Jan 5, 2009 | 07:18 PM
jayrav's Avatar
You should either upgrade your rear TB bracket(Teraflex rear TB bracket that comes with 3" lifts and up) or an adj rear TB if you plan to go higher. As for the swaybar links, in my case I needed them to be longer because I plan to go up to 5" of lift.
My advice to you is give Mel a call at ORE. He'll be more than happy to answer all of your questions.
Good luck!
Old Jan 6, 2009 | 09:34 AM
Leonard Massi's Avatar
Originally Posted by evolution
What is it Rubbing?
The Hose from the resevoir is rubbing on the plastic of the components in the above engine compartment. I've tried removing some of the plastic but every time I take some away the hose shifts and rubs in another spot. It's starting to wear through the outside of the hose, is it a steel braided line covered with a blue rubber?
Old Jan 6, 2009 | 10:15 AM
asjackman's Avatar
on Evo' website they list the front coilovers as a bolt on, anyone know more about this option?
Old Jan 7, 2009 | 06:17 PM
jayrav's Avatar
Dude, call Mel!
Trust me, I have spoken over the phone with most of the guys/gals at ORE and they are very very helpful when answering all of my questions. That way you get the info first hand from the source. So feel free and give them a buzz. They don't bite
You won't be disappointed.
Good luck!
