fender build help!!
[SUP][/SUP]
If you dont find one of these.....
Make a mock up one out of cardboard, get someone to draw it for you on autoad then get it plamsa cut. If some areas need to be field fit later, that is okay just have it cut a bit bigger in those areas and you can trim it down later (or add the holes later).
You'd probably end up saving a buck in the process too.
One last comment - send me the cad drawings once youve done this!
[SUP][/SUP]
My only problem I might see here is will frame flex (versus body flex) just bind things up too much?
