Flipped Tie Rod Drag Link ??? What does that mean ???
I would like to install a beefier and stronger tie rod and drag link but I don't know the difference of some of the kits available. Terraflex for example has an HD tie rod and drag link kit and they also have HD tie rod with flipped drag link kit. What is "flipped" mean and what does that get me? Which do I choose? For some background info...I have a lifted 2 door 2014 Jeep JK Rubicon with a 3" Rock Krawler X Factor lift. I'm currently running 35" tires. I do wheel my Jeep. Thank you in advance for suggestions and replies and I'm sorry if I'm not in the correct forum for this.
Flipped means that you drill out your knuckle and run the drag link on top of the knuckle instead of under the arm. You flip the link up top. You also need to run a raised track bar bracket on the axle so you keep the two links parallel. This is something to look into if you are running 3.5" or more of lift since it limits your up travel due to the frame and requires 3.5" of extra bump stop. It is often referred to as a high steer kit or option.
