hemi's flex
Yeah that tie rod looks scary. Are you still running the same shocks that came with your 5.5" kit even though you threw on the 2.5" spacers? If so you may want to consider buying longer shocks and some limiting straps to take advantage of your gigantic lift.
If you don't want to do it yourself, any decent shop should be able to build some pretty quickly...
