Hi-Lift rollbar mount
Old Mar 27, 2008 | 03:00 PM
chaddlane's Avatar
Wink Hi-Lift rollbar mount
For those of you that are interested I mounted my Hi-Lift jack to the rear roll bar. I will be putting up pics as soon as i get them developed (old school, I know). I fabricated two brackets and welded 3 1/2" long 1/2" grade 5 bolts into the; Then welded those to the rear roll bar. I also drilled a 3/16" hole in one of the bolts so i could lock it with a small pad lock. I secured the jack with wing nuts for easy removal. It looks very clean.
Old Mar 27, 2008 | 03:15 PM
x No Compromise Offroad x's Avatar
Not even worth hearin about without seein it!
Sounds like a good idea though....
Old Mar 27, 2008 | 05:24 PM
chaddlane's Avatar
i finally got the pics . sorry some are bad they were taken with an old disposable camera.
Old Mar 27, 2008 | 05:29 PM
whtIwrk4's Avatar
That's the best one I've seen yet. This is probably the way I'll do mine. Thanks for the idea. You should make this a write up and put it in the write up's section.
Old Mar 27, 2008 | 06:02 PM
drbeddow's Avatar
x2 on the writup. That's a very clean setup. Well done !
Old Mar 27, 2008 | 06:07 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
That's a nice job....well done.
Old Mar 27, 2008 | 06:09 PM
A'sJK's Avatar
You rule!
Old Mar 27, 2008 | 06:55 PM
There you go...that looks GOOD...unfortunately my 2door doesn't have that extra bar...but it's a awesome mod...
Old Mar 27, 2008 | 07:07 PM
jerseyjk08's Avatar
I like that a lot. good job
Old Mar 27, 2008 | 07:10 PM
BYU JK's Avatar
nice work. looks great
