JKs w/o lift with After Market wheels & tires - Post Pics!!
They are not 17's but they come in 17's....
It is a black jeep with black wheels though, no lift, you may have to take the air dam off if you went this big...
33x12.5's should fit pretty good. Taking the air dam off really is not a big task and you can put it on when you turn her in, otherwise people just trim the air dam but the dealer will ding you on that for a lease.
Anyways, they are xd cranks.
They are 9" wide and come with 5" back spacing.
As for the tires, nitto trails (305/55/20's which measure out to 33.4 x 12.6)
Noise - just enough of a hum to make you smile but not bad at all.
Getting bigger tires, not regearing.... Get a superchip, it will correct you tire size and shift points otherwise without it your jeep will seem like it lost all of its power due to the bigger tires.
The best thing about it is that you can switch everything back to stock when you bring your jeep in to be serviced in a blink of an eye and the dealer will never know that you have it.
Good luck!
Good luck!
Good luck!
Good luck!
These are 265/75/16 Goodyear Duratrac's on 16 inch ProComp 7089s (no lift). I have over 50K miles on them and they are still running great! I would recomend them if you want my opinion. In fact when these go, I will be getting the 285/75/16 size!
