Lights....Lights......Lights
Old Nov 16, 2010 | 06:21 AM
BigRed0625's Avatar
Default Lights....Lights......Lights
Hey yal well im pretty pumped to put the 6 new KC's i just ordered on my new custom lightbar. I am just curious what i should do for power/wiring! Am I goin to need dual batteries or can i get a nice optima or semthing to power it?
Any pics of your setup or advice would be excellent! Thanks
Old Nov 16, 2010 | 11:54 AM
westchester's Avatar
KC's usually come with the wiring harness, or can be bought for additional $. Check and see. If not, you can purchase the relays, switches and wiring yourself, but a ready-built harness is alot easier.
Old Nov 16, 2010 | 12:01 PM
josh_jacklyn's Avatar
when i purchased my light force lights i had to get a wiring harness for an extra 60 bucks,but let me tell you it made the install super easy. good luck
Old Nov 16, 2010 | 12:03 PM
I reread your question, I still think you wanted info on the wiring, but to also answer your battery question, it depends if you plan to leave the lights on for a decent time with engine off.
I have Benchmark's dual battery tray with 2 Optima Yellow tops, but wanted it mostly to handle winching and to run a 12v fridge for extended time.
Many here have complained that their stock battery failed, so its good insurance to upgrade it, but I'd expect your lights to be powered just fine with a single battery, whether stock or not, with engine and alternator humming.
Old Nov 16, 2010 | 02:08 PM
Christine's Avatar
I'm running a bunch of lights on mine and after reading threads on the forum, knew the stock battery would soon die. I bought a DieHard Platinum battery. I actually bought the Marine version because it has 2 sets of terminals.
Old Nov 16, 2010 | 02:27 PM
BigRed0625's Avatar
Thanks for all your help! Does anyone have pictures of how they ran there wiring? I plan on running the wiring from my lights on top of the windshield through the piping of my custom lightbar, then through the back of the hood close to the windshield mounted lights!
How did yal run the wires and how did you run them inside the jeep for switches? I heard theres a hole in the firewall? I dont know, any input and/or pictures would be excellent! Thanks.
Old Nov 16, 2010 | 04:44 PM
wallawallaron's Avatar
https://www.jk-forum.com/forums/show...gh-beams:beer:
Old Nov 16, 2010 | 04:46 PM
Originally Posted by wallawallaron
https://www.jk-forum.com/forums/show...ation-Write-Up Hope this helps
Old Nov 16, 2010 | 04:49 PM
http://www.kchilites.com/wp-content/uploads/2010/03/6315_Harness_web.pdf
Last edited by Moochie; Nov 16, 2010 at 05:12 PM. Reason: Please, no clickable links to non sponsors
Old Nov 16, 2010 | 06:17 PM
AK4Dave's Avatar
What...???? I installed my 240 Blitz without their $60. rip off. Nothing to it....easy as pie.
